Full speed pressure = 19.5psi
Pipe Run from returns is approx 66’ - by steps - right end in pix
Pipe run to suction is approx 113’ - left end in pix
Plumbing is 2”
2 suction runs (1 skimmer and main drain)
It shows % but I can change to RPMs. I’ve also discovered a “diagnosis” button which gives me the watts for each % setting. Your full speed # was very close, watts used read 1063 at 100%.
Thanks again for taking the time to answer my question.
