Hmm - Hayward VS with Pentair automation.... how did that happen?
Try turning off the pump circuit breaker for 15 minutes.
While you are waiting - on the EasyTouch, put the automation in Service Mode.
Once the pump circuit breaker is baxk on, give the pump a couple minutes to boot up and see if you can control the pump via the pump control keyboard.
How is the pump wired to the automation panel?
In Service Mode, do you have 220v to the pump motor - checked at the pump?
