Hi all,
I have a Hayward Super Pump C48K2N143B1 and a waterway crystal water cartridge filter. The pump is overheating and shutting off. I can hear some air-gurgling noise. However, I don't see any air bubbles in the pump basket. I do have a leak on the pressure relief valve on the filter. I think it's a bad o-ring, which I plan to replace (or just see if needs more lube).
Do you think the leak on the filter, can cause an air leak in the pump and cause it to overheat?
Per my understanding, the air leak should be on the suction side (i.e. between the skimmer and the pump), for it to impact the pump. The pressure gauge on the filter reads 20PSI which it has always read. I use a robot so I don't vacuum using the pool pump.
Any tips on how I should troubleshoot the pump overheating will be much appreciated. Thank you!
