Hi all,
I have a Hayward Super Pump 2 (0.75 HP) that is humming and not starting (trips the breaker after a few seconds). However, if the impeller is given a nudge, it works well. Hence it seems to be the capacitor? I was going to replace the capacitor and there is a difference in the MFD/uf range (MFD = UF).
Old capacitor says:
124-148 MFD
125 VAC
60HZ
The new capacitor (available in store) says:
161-193 UF
125 VAC
50-60HZ
1) Am I correct to assume that it is indeed the capacitor that needs to be replaced?
2) Will there an issue if the new capacitor has a higher MFD/uf rating?
3) How do I find the original part number/specifications? Pump picture attached, but not sure where I can find the original capacitor specifications online.
Please advise, thank you so much!!!!!
Old capacitor says:
124-148 MFD
125 VAC
60HZ
161-193 UF
125 VAC
50-60HZ
