Hey gang!
So I've got this old Hayward pump that is leaking. I can see the water dribbling out where the motor mates up with the housing. I understand there are one or more gaskets in there that may be the culprit. The motor was replaced last year, however the pump assembly is probably 15 - 20 years old. I don't believe any gaskets were replaced at that time (a pool service did the work). The part number and serial number have faded with time. So I'm looking for a proper identification of the pump and/or replacement parts needed and recommendations for a quick fix.
The leak started last year but was barely an issue. But now I did a bucket test and am losing around 1/2" of water a day while the pump is running and you can see all the leaked water. So that's not good. Can I just crank down on those four bolts a bit?
