Hayward Power-Flo Matrix Wiring Help
May 14, 2018
17
Toronto
Pump stopped working today. Took back cover off and the switch was fried. Literally. Have ordered a new one. Hoping for some guidance on putting it all back together.
This is what I opened up.
So.
The plug has three wires- green, white, black.
The green is ground. Attached in the pick. The white is the neutral, was attached on the L2 terminal as pictured when I opened up. The black was scorched and not attached anywhere upon opening.
The on/off switch was attached via the red wire on L1 you see in the photo.
Where does the black wire go? Next to the red on L1? I’m confused a bit here.
Any guidance much appreciated.
Then your good to go. The red and black at the switch is just breaking the hot side. The wire in your motor are good just need to be routed through proper fittings per electrical code. Make sure to bond the motor.
