I opened a pool in my new house in May. It is a 24 foot above ground. The filter is a Hayward Perflex DE. The pool and pump are about 20 years old and the previous owner replaced the pump 5 years ago. This is my first time using an earth filter. I’ve had advice from friends and family, everything is great for the most part but I have some questions. When I first opened the pool I added 2 lbs of earth until the pressure gauge stopped at 18 psi. I added a 3rd pound and the gauge did not move. I was told to add until the pressure stops rising. So I backwashes the filter for 1 minute thinking I had too much earth. 2 months later the pool has perfect chemistry and everything’s fine. Yesterday I accidentally ran the vacuum losing prime because of air and lost some DE through the jet for about 30 seconds. The pressure is still at 18, no remnants of de are visible. Everything seems to be fine. I did some research to see if I have lost to much DE only to find that on the filter label it says I should’ve added 5lbs of DE. So I have the following questions. Did I add enough de to begging with? Should I add more? Is my pressure too high? Should I just leave well enough alone? The pressure had risen from 18 to 19 after 2 months of operation. I did bump it to see what happened and it went back to 18. Thanks in advance!
