Hayward OmniLogic new mode
Dribar
0
Sep 27, 2017
1
Sarasota, FL
We have a very typical pool/spa configuration where the spa spills into the pool when you’re in pool mode, and automation flips valves so the spa is isolated during spa mode... very typical.
Question is: can I setup a new mode where all of the return goes to the spa and the main line to the filter comes from the pool? I want all of the water from the pump to go into the spa, spill into the pool and then return to the filter.
I can do this manually by just switching the valve that controls the return... I am just wondering if I can do that in the OmniLogic instead of me doing it manually at the valve.
Let me know and thanks.
BigDan
Dan,
Welcome to TFP... A Great resource for all your valve flipping questions... :drown:
Most automation system have three modes of operation...
Pool mode... where the water is sucked from the Pool and then returned to the Pool
Spa mode... where the water is sucked from the Spa and then returned to the Spa..
Spillover mode... where the water is sucked from the Pool and then returned to the Spa.
Check out page 18 of your manual... https://www.hayward-pool.com/pdf/manuals/OmniLogic_HLBASE_Ops.pdf
