Well, just barely. I works fine for about 6 mos when the air temps are in 80's & 90's, heating to my preferred temp of 82, but in winter, when I really need to heat my pool, nada! Right now it is 60 outside, and the pool is at 75. The pump/heater has been running for 2 hours. This is pretty consistent - by the end of a day like today the pool might get up to 77. But then overnight it cools to low 70's again. Tried heating my spa yesterday in similar weather - after 3 hours, the water temp went from 73 - 90. Normally, it gets to 102 in summer, but even that takes almost 2 hours.
Pool is approx 12 ft X 30 ft, ave depth around 4 1/2 ft.
I understand that a heat pump takes heat from the air, so it's not as efficient in cool temps. (My electric bill is generally much higher in winter than summer) But 60's isn't all that cold! Shouldn't it be heating faster?
I believe now that I was misled by my (AWFUL) builder (both he & his pool company are defunct) to use an electric heat pump rather than a gas heater. Would it be better to switch out the heat pump? SUpposedly there is a gas line near the pool equipment.
