HAYWARD H400FDP HEATER WITH “CE” ERROR CODE
Bigote
0
Oct 27, 2017
2
Deltona/FL
My pool heater came up with the “CE” error code a while back.
The service manual states that this is a communication error between the display board and the control board.
I replaced the control board and it did not clear the code.
Replaced the display board (which comes with the ribbon cable already attached) and the problem is still there.
Replaced the fuses board and no change. The dreaded “CE” code is still present.
Ordered a second control board and the problem continues.
I noticed that the part No. for the control board (as per the service manual) is FDXLICB1930. This is the same part No. I have used to buy the control boards. I have bought them from pool company that I found in Internet.
The damaged control board that came out of my heater has a sticker with a Hayward Pool number 1102285201 0160-0042 VER20.
Does anybody has an idea if these boards are interchangeable ?
Are there different versions of these boards ?
Any help will be appreciated.
