Hayward H250 IDL AO Error Code
Kevink
0
42
Austin, TX
I just replaced the combustion blower motor in my Hayward H250 IDL. The old when made some funny noises then just quit altogether. When it quit, I did NOT have the AO error. LED display was normal and the heater just hummed on start up but no blower.
Now after replacing the blower with a new one, I have the AO error. Heater starts up, I can hear the blower working fine, then after 30 seconds or so I get the AO error. I checked the tubing, it looks good. Any ideas? Not sure what would cause the AO error now after replacing the blower motor. It was working fine until the day it went out.
Is the blower connected to the right voltage?
Note: Do not change the voltage unless you are 100% that that is the right thing to do.
If you connect 230 volts to a 115 motor, you will destroy the motor.
AO CODE POSSIBLE CAUSEMAIN FIXES
VACUUM SWITCH TUBING IS FAULTYReplace tubing
A FAULTY VACUUM SWITCH WIRINGSecure Wire Harness Terminal to Spade on Vacuum Switch
BAD BLOWER WIRING OR CONNECTIONEnsure Blower Plug Is Fastened on The Control Module
A DEFECTIVE VACUUM SWITCHMeasure Resistance on Blower Windings
BAD BLOWER RELAYMeasure If 120VAC Is Present on Blower Relay Endings
VACUUM SWITCH IS DEFECTIVEReplace A Defective Vacuum Switch
The entire page with test procedures is here:
Reactions: Kevink
Thank you
