- Jun 8, 2020
- 23
- Plaster
- Hayward Aqua Rite (T-9)
Hello everyone. I'm located north of Dallas and felt really good going about being prepared into this weeks cold weather. Everything was going fine until this afternoon when I noticed that the pool had turned off. I assumed it was because in the sunlight the air temp sensor got about 32 degrees and had cut off the freeze protection. Fast forward 3 hours and it never came back on and the reason why is the air temp sensor believes it to be 47 degrees outside currently. For the time being I've got the pump running and am cycling between pool/spa mode every 30 minutes manually. Does anyone know a way to force the system into freeze protection mode? If not it looks like it's going to be a long night for me manually cycling things until the pool supply stores open in the morning.
