Hayward DE Filter Air Relief Valve Leaking
DanF
610
Chandler, AZ
CircuPool RJ-45 Plus
Hi All,
Noticed that my air relief valve is leaking at the bottom and out the hole where the air/water escape, as shown in the picture. I am guessing that as a minimum I will need to replace the valve, but do you think I should replace the entire assembly?
Filter is 5 1/2 years old.
Thanks.
Dan,
I'd just get the $10 part..
Keep in mind that if the leak is dripping out the end air vent hole, that the valve can get clogged with junk from the inside.. I've fix mine a couple of times by just blowing water backwards through the air vent valve..
I always make sure to blow it out when I clean the filter..
Reactions: DanF
I had the same issue a couple of years ago. No matter how tight I tried to close the valve, water would still dribble out. I bought the $10 part you are referencing and that took care of it. Mine was at least 10 years old at the time.
Reactions: DanF
Thanks guys. I'm leaning toward replacing just the valve (the $10 part), but in order to replace that, I need to remove the whole assembly (the $80 part) anyway. Decisions, decisions...
Thanks everyone. I ordered the $10 valve from Amazon, and installed it today. So far no leaks. There are 2 or 3 pretty good videos on YouTube which guided me through it.
Reactions: jark87
