I have 3 colorlogic lights and the one in the spa started getting dimmer and finally failed after about 2 years. I pulled it out this weekend and found water inside the LED area. Looking at it raises a few questions I am hoping the community can answer:
1) water inside the LED part is BAD I am assuming (pic 1) - I imagine that is why it failed, right?
2) what is all the black gunk (pic 2)? Some sort of sealant?
3) The manual specifically sates: "Insert the ColorLogic/CrystaLogic 1.5” LED light fully into the conduit as shown. IMPORTANT: Do not use silicone or any other type of sealant".
Could this have caused the failure?
4) When I install a new one should I just put it in the conduit and not put anything (e.g. black gunk) around it?
5) Given how expensive these things are, would you recommend switching to a different light, either within the Hayward family or from a different manufacturer? Keep in mind i have 2 other colorlogic lights that are working fine (knock on wood)
Last couple of pics are just to show the labels on the light.
