Has anyone used the Oceancare tile cleaner?
Nikilyn
0
1,334
Gilbert, AZ
Pentair Intellichlor IC-40
We were in the pool today and noticed the grout is starting to get dirty above the water line. We want to clean it before it gets bad. What do you recommend?
A stiff brush and pool water.
Do not use any type of acid solution to clean the grout. Over time it will weaken it and remove grout.
Reactions: Nikilyn
That dirt is in the pores of the grout. Anything you do harsh enough to get the grout clean will wear away a layer of grout. Accept that stuff outdoors accumulates dirt.
You can try a gentle cleaner on it like 409.
Reactions: Nikilyn
It’s just really weird how most of it is above the vertical grout line and forms a T. Around most of the pool it is clean above the middle of the tile. This was the section that had it the worst.
