I live in the Tampa Bay Area and we have very hard water. I recently purchased and installed a Caldera spa with the Freshwater swg system. It recommends a CH of 50 but our fill water is about 200-250.
The spa store has some sort of pillow you can put in and run the Vanishing Act process on the spa to lower CH but it takes about a day of running it (6 hours per run) to get CH in the right levels. Not to mention the cost of purchasing a new pillow every time I refill.
I’m considering the addition of a water softener for the house as it would also improve other water concerns in the house but not sure what route to take.
I was looking at a no salt option such as NuuvoH2O for its simplicity and easy installation but not sure if this actually solves my CH problem in the spa. This system appears to convert the calcium bicarbonate to calcium citrate and allows it to pass through.
Will that actually work for my spa? Will I get correct CH readings? Anything I’m not thinking about or considering?
Much appreciate the help!
