I have rapidly reach the limits of my competence. I’m a new pool and hot tub owner (both came with the house I purchased in April). I have not touched the hot tub until the last several days. The previous owner said something was wrong with some of the jets but didn’t know and didn’t want to fix it. The hot tub is a Nordic Encore.
So fast forward to two days ago and I started my investigation into this hot tub. First, I drained it, cleaned it, removed the jets, cleaned them, removed the filter and cleaned it, so on and so forth.
This afternoon I filled up the hot tub from the filter port to avoid air pockets (which it appears I did). I got the water level to the appropriate level and turned on the pump. Only to find that two of the seats and the lounge seat have weak water pressure while the rest has strong water pressure.
This is where I am completely stump. I do not believe it is the pump as I have strong pressure on three of the 6 seats. Any help would be appreciated. I’m trying to avoid calling in a “professional.”
