Hi
Thanks for any help here. I use TF-100 test kit.
FC 4-5
CC 0
PH 7.5 - 7.8
TA 220 This has been this since startup and is about 200 from tap water
CYA 50
SALT 3700
I have two problems first my grand kids and wife use the pool about 4 times a week. Then are complaining that it seems their hair is not growing and getting shorter. They have actual took pictures to compare. They have a picture from 5 weeks ago and one from now and the hair length is shorter and the hair looks lighter like it was bleached.
My second problem and I do not know if it is part of problem number 1 is my salt generator. I have had a problem with it from start as now my pool is about 1 1\2 years old. My salt level has always been between 3300 - 3700 my generator is for a 40000 gallon pool but my pool is 5000 gal in ground fiberglass and not very big. I run it everyday but it seems it does not produce chlorine. Example I run it on 100% for 7 hours a night and when I test the chlorine it has not gone up sometimes down could be this way for 5-6 weeks and then it seems to start to work as I see the chlorine level go up and I have not added any chlorine at that time to the pool. The manufacture of the generator has been helpful and they even sent me a complete new system. So I had the system replaced with the new one and still the same problem. I have basically gave up on the salt system. I run every night and I test the chlorine every morning if it needs chlorine I add with liquid
12.5% bleach from pool supply store. So I maintain the chlorine level with the liquid and it works well and the salt level stays at 3700. I do not see how this could be cause of the hair issue. My PH is also always about 7.5 but the alkalinity is high like 220 but has always been this but PH is very stable. Could the alkalinity be my problem. Equipment is ok and eyes do not burn and no skin problems just seems like it is affecting the hair. Thank you for any thoughts and help.
Greg
FC 4-5
CC 0
PH 7.5 - 7.8
CYA 50
SALT 3700
Greg
