Hi All,
I have a solar pool heater and part of the system is this GVA-24 actuator that controls whether the water flows up to the solar panels or not. Recently it has started to leak. I opened up the device and lubricated the o-ring I found inside (based on what I read on TFP. However, that doesn't seem to have stopped the leaking. The leak seems to be coming from behind the unit. I have added some pictures to illustrate where the leak is happening.
Any suggestions for a fix would be greatly appreciated.
