I am an American living on the Mediterranean coast, where we have long, hot, dry summers. Our apartment pool and terrace tile has always been grouted with flexible siliconized grout made for pools, with the brands available in Turkey. Our overflow drainage trench (which has been covered with liquid insulation and mesh the past 3 years, tile underneath), has recessed ridges at the top to support the plastic grating. There is L-shaped plastic trim installed on those ridges around the entire perimeter. Each year we do grout repairs before opening the pool, but there always seem to be increasing cracks in the grout line between the plastic trim and the hard border tile. One pool engineer here said that trim is useless; recommended that we remove it, seal the exposed surface with more liquid insulation, and just sit the grating directly on top of the ridge. Another pool engineer said the plastic is fine; just remove the old cement grout and fill it with epoxy grout instead. I have read and been told that epoxy grout has excellent durability between ceramic tiles. However, since the plastic is prone to flexibility, the hard epoxy could crack and separate at the edge. I am having trouble finding information about this precise problem here. I would appreciate any professional advice. Thank you!
