Within the last few days, I have been noticing that the pool pump has been making a grinding noise. I stopped the automatic scheduler as soon as I took a few videos. I cleaned the basket that had some tree debris, but there may be other material clogged in there. Here is the 5-second video. I can hear the noise from 20 feet away.
Yesterday after cleaning the basket at the pool pump, I inserted by hand in there and found a rotating component, manually rotated it, but couldn't feel anything solid that could be loosely moving around when the pump runs. When I closed it up all, the noise totally disappeared and the pump ran without any such noise for a few hours. But The noise is back again when I started the pump this morning. It is highly unlikely that there is a whole lot of new debris when the pool pump had been stopped. That observation gives me hope that it is not a permanent problem (at least not at present) with impeller or any bearings, but I could be wrong. The noise is coming almost exactly where the bolts are in the video.
I don't see any water leakage.
I read a few other threads that indicate that one might have to remove the bolts, pull the motor back and remove a few components.. Are there easier things I should try first?
- I see two plugs on the side of the pool pump, presumably one of them to remove the remaining water from the skimmer and the other to remove the remaining water from the impeller area. Can I open those up (after having powered off the pump with circuit breaker) and see if that clears the debris (assuming debris presence)?
- Could I spray water with a garden hose into the pump trying to dislodge the debris?
- Can I open those drain valves fully, just enough to jet-spray water through them into the impeller area to dislodge any debris?
The pump was new when installed in Jan or Feb 2017.
