Hi there,
I've had to rip out a bunch of plumbing and I ended up plumbing in some unions because I just couldn't figure out how on earth they had hard plumbed everything without one single union. Well, I have two more lines to do and I'm wondering whether I can learn whatever this technique is and avoid more unions- I just can't figure out how they would do it. The lines are hard lines so there is almost no give, and if I get the pipes close to each other and glued on either side, how can I join them? It would be impossible to stretch them apart and put in a coupling, and if I could it would be very hard still to glue both ends of the coupling at once. So, what is the secret?
I'm attaching a photo of how this was previously plumbed with no unions. Also, there is an apparently dead loop there that you can see hooks up both ends under ground. I believe that's where the heater was plumbed in. Well, the joins in there are leaking underground we have just discovered and so that funny loop is one of the lines I'm going to be playing with. The other is from the new Pentair Multivalve to waste.
Thank you for your help!
Angela
Angela
