- Mar 14, 2024
- 76
- CircuPool RJ-60
Is it necessary to do so or just leave them on the existing breakers? It's been this way for 25 or more years.Those are two, standard 20A, non-GFCI circuit breakers.
GFCI breakers are labeled as such and have a “TEST” button on them (and sometimes an LED light) to let you test the breaker for a ground fault as well as letting you know the GFCI protection is active. They look very different than what you have there.
If you are wanting to add GFCI protection to that circuit, then you need to replace those breakers with the Pentair (rebranded Seimens ) breakers.
It’s ok the leave the SWG on the same circuit.
A word of caution - GFCI breakers are sensitive and can sometimes “phantom trip” for no reason. You’ll need to keep an eye on the pump (and SWG) operation to make sure that they are working as intended. It’s impossible to know beforehand if you’ll experience phantom tripping so you’ll just have to install them and see what happens. If phantom tripping does become a problem, you may have to separate circuits or move them around to see if that stops it. It’s simply one of the downsides of putting everything on GFCI (or AFCI) breakers.
Nope.Do you have a pool panel also ? There may be a GFCI breaker for the pump there.
That's how I did it. And now the timer turns on the SWG inside of the pump program time. I guess the risk is that the pump trips OFF..the SWG timers ON ... and the Circupool switch fails.....boom.Breakers need to be GFCI by code once you upgrade.
You asked if the pump and cell can be on the same circuit ?
Yes they can be on the same circuit but at the timer the pump needs to be on the line side of the timer so it has constant power and the SWCG should be on the load side.
Since you are not upgrading your service, rather only replacing motor, then leave the 20 amp breaker alone. It is perfectly acceptable to leave it alone.Breakers need to be GFCI by code once you upgrade.
Legal and best practice are two entirely different things. It's one thing if someone doesn't know better. Once they know better they are possibly jeopardizing their family's safety for peanuts. (no matter how small the risk, it IS a risk).It is perfectly acceptable to leave it alone
I had already purchase the Pentair GFCI breaker. Will stab it in the box later this week.Legal and best practice are two entirely different things. It's one thing if someone doesn't know better. Once they know better they are possibly jeopardizing their family's safety for peanuts. (no matter how small the risk, it IS a risk).
someone above stated that they needed to change. That is not correct. They did not upgrade the service. I was pointing that out. If my fridge dies it does not mean i have to change my breaker for the new one, so the same with my pool motor.Legal and best practice are two entirely different things. It's one thing if someone doesn't know better. Once they know better they are possibly jeopardizing their family's safety for peanuts. (no matter how small the risk, it IS a risk).
Fridge circuit codes don't state that all new circuits require a GFCI. And even if they did, your old circuit would be grandfathered. But if your family's safety was at stake, you'd be an idiot to leave it non GFCI on a technicality.If my fridge dies it does not mean i have to change my breaker for the new one, so the same with my pool motor.
its not side skirting. The fact is is does not "need" to be replace. Better wording would have been you can replace it at this time as it would be an easy time to complete. Again an ignorant person might gloss over the distinction and not realize that they do not "have" to replace. Some believe need is a synonym to must. It aint.not how to side skirt either.
You're right. You also don't need to remove power to work on circuits. It's just a really really good idea to do so.Again an ignorant person might gloss over the distinction and not realize that they do not "have" to replace. Some believe need is a synonym to must. It aint.
