So as the title states and I getting ready to install the 18x9x52 intex pool and I am trying to make sure I do it right. I found a picture for the overall dimensions (including the supports) and the picture looks a little confusing and I am concerned that it is off a bit. I measured a total area of 11 feet by 20 feet, which according to the picture I saw should be fine, but I am concerned it doesn't cover one side of the pool with the supports based on the way it is drawn. Can someone confirm that the overall dimensions are 10'10" x 19'10"?
Secondly, they say to use 15" x 15" X 1.2" pressure treated support pads, for the life of me, I can't think of anything that is that size. The largest I can think of is a 2x12 which is obviously not 15 inches. What do people use?
I picked up some of these at Lowes:
Shop Cap Concrete Block (Common: 4-in x 8-in x 16-in; Actual: 3.625-in x 7.625-in x 15.625-in) at Lowes.com
These are 16" x 8" x 4", but my concern with these is getting them lined up perfect so the majority of the weight is in the center of the 8 inches essentially. Are these good for the pads? What else have people used?
Once figuring out what I will use, how to do you make sure everything is lined up? It sort of seems like a catch-22 situation, where I can't put the pool up til its level, but I can't figure out what level is until I lay out the pool and line everything up. The area I am installing it has tons of rocks buried in the ground making it EXTREMELY difficult to dig out after the fact, etc. So my thought was to get all of the pads level sticking a little above the earth to allow me to fill the rest of the area with sand.
This is kinda of hard to explain in text, but hopefully I conveyed the idea a bit. Any thoughts and/or help would be great!
