I have a basic understanding of water chemistry from managing a 90K private pool for 15 years. However, I understand hot water chemistry is a lot different. At this point I have decided on the Frog Ease Floating system.
Found out about Spa Marvel, Total Serum and Ahhsome. JIm at awesome is awesome. He even called me personally about an issue I had a question about.
Anyways, it seems from all research that Ahhsome is the better product of the 3 I mentioned earlier. The tub has a UV-C sanitation system (not sure what that is) if that makes any difference in how you answer my question.
My question is this. Should I use the Ahhsome Hot Tub Jet Cleaner for the initial purge and for all purges and use the Aqua Clarity for regular maintenance or just use the Aqua Clarity for purging and maintenance?
I will gladly accept and suggestions. Just to muddy things up a little, I plan on using Spaguard for my balancing and Spazazz crystals for my aromatherapy.
