- Feb 2, 2023
- 36
- Plaster
- Jandy Truclear / Ei
Aloha! I will be getting a new/replacement TrueClear SWG cell. I live in an island so ETA for the cell is about a week. The control panel of the SWG cell is intermittently reading to check cell and chlorinating at 30% (my setting). I did clean out the cell to make sure it just needs cleaning. I will replace it no matter what. My questions are; 1) Can I just keep the SWG running as-is (it's going to be replaced anyway) or do I turn it Off? 2) If I turn it Off, I just have to monitor the pool water chemistry and keep it balanced until I get the new SWG cell. Do I go back adding Chlorine tablets in the mean time?
I have another issue. The pool is leaking. I did the bucket test and I've been refilling every 2 days. Before it was at least a week before I needed to refill. Also, our water bill doubled. Leak test kit is ordered and ETA about a week. Hopefully, I can fix the leak myself.
Water chemistry
10/8/2024 10/10/2024
pH 8.2 8.2
FC 3 9 (after adding 10% liq. chloring on 10/9)
CC 0 0
TC 3 9
CH 525 525
TA 60 70
CYA 40 40
Salt 2200 2400
Ever since I've been maintaining our pool myself (Thank you TFP!!!!), my CH was always high 900+ so I've been adding MA quite often based on CSI recommendation. But, I suspect, because of the leak and constant refilling, my CH dropped. I will check my water chemistry later. Question: If Salt and CYA level is the same, and FC is around 6, per Pool Calc, I need to add Salt and Chlorine stabilizer. Right?
I will update my post with latest pool water numbers. I use a TF-100 test kit.
Thank you!
Water chemistry
pH 8.2 8.2
CC 0 0
TC 3 9
CH 525 525
TA 60 70
CYA 40 40
Salt 2200 2400
Thank you!
