So we purchased a above ground pool for the summer. Just got it all filled up and ready to go. And the pump started leaking from the bottom of the unit. It's not coming from any of the inlets and all the connections are tight and sealed . It's coming down from the internal area. It's pumps strong and the return flow is good, seems to be working great aside from the leaking. ( Leak is more then steady ) Im not able to find any diagrams for the model to determine if there is a seal that needs to be replaced . Or is there anything else that would cause this leak . TIA
flowclear model 90403E . For the 2500 gal .
