Hello everyone. Need some advice. I just put up a Bestway 18x48 above ground pool. Painstakingly leveled the base to ensure a nice level pool and had the water delivered today. I'm checking east post and know that there might be a little shift as the water fills and the liner sides form to accommodate the water. Basically I wanted everyone's opinion as to if they look OK? There are a couple with a slight tilt inward which I wanted to check with you all about. I appreciate you all taking the time to look.
