“Filter” setting vs “Recirculate/Circulate” setting question! (Sand filter)
thefloatqueen
1,377
Columbus, Ohio
As seen in my signature, I have a 16” Intex sand filter pump. OBVIOUSLY I know the difference between the words filter and recirculate (one goes through the filter media, other does not), but can anyone give me some examples of situations when I would use the recirculate cycle instead of “filter”? I always have it on the filter setting when the pump is running unless I am backwashing. I looked through my filter pump’s owner manual and all it tells me is what it does but not when it is appropriate to use it. Thanks in advance!!
Recirculate is when you don't want the water to filter. The water pumps, but no filtration.
No one ever used that. lol
Well I know that haha! I just didn’t know if there is time when you would recirculate the water without going through the sand media. I thought maybe after adding certain chemicals or something? LOL. I’ve never experimented but asked this out of pure curiosity. Thank you for your answer. ;)
  • Haha
Reactions: frogabog
Use RECIRCULATE if you have a bad algae problem that is rapidly clogging the filter so you constantly need to backwash. Do the initial SLAM Process on RECIRCULATE until you kill much of the algae. Then filter out the dead algae without the algae continuously multiplying as you try and filter.
Or if you use Floc (that we don’t recommend doing) and intend to vacuum it to waste when it settles to the bottom of the pool. Run the filter in RECIRCULATE to not clog the filter with Floc or Clarifier.
Recirculate can be used when the filter is in need of repair - if you can't filter the water, at least you can circulate it
Thank you for explaining that! Makes perfect sense now.
Reactions: thefloatqueen
Learn something new every day! Thank you so much for letting me know all of this. Great info!
