I spent considerable money to fix a 30 year old gunite pool with fiberglass. The work was done late in 2016. At the end of the 2017 swimming season, I noticed the white blume when brushing. I called the pool contractor this spring and was told that the gel coat was failing because I had not kept the water chemistry right. When I closed out on the pool in 2016, they had me sign a document that states that I understand that I need to keep the pool chemistry as follows:
Chlorine: 1-5 ppm
pH: 7.6-8.0 (recommend 7.8)
Total Alkalinity: 80 - 120 ppm(recommend 100)
Ca Hardness: 300-350 ppm
CA: 30 - 80 ppm (recommend 45 )
"EXCESS CALCIUM AND/OR CHLORINE DEFICIENCY WILL CAUSE DAMAGE TO YOUR FIBERGLASS SURFACE RESULTING IN POSSIBLITY OF VOIDING YOUR WARRANTY".
i had been using a pool store to check my water. I had kept the water reports which showed that in general, my Total Alkalinity was around 100 ppm and my CA Hardness around 300 ppm. The CA was around 75 ppm. But still, they want me to accept that the failing gel coat is the result of my poor maintenance. The proposed solution is to drain the pool; acid wash it and gel coat again. $2800. My issue is, I have no reason to believe that it would do better next time as I'm not convinced that the water chemistry was the issue. Exaperating.
Chlorine: 1-5 ppm
