- Sep 21, 2023
- 11
- Fiberglass
- Hayward Salt & Swim 3C
Hi! I'm new to TFP forums but it seems to had a lot of experienced people there concerning pool maintenance!
So I will try my shot if someone can help it will be much appreciated! By the way, I'm a french canadian from quebec and the english is not my primary language so excuse me for that in advance for my writing skills.
So let's begin, I have installed in my backyard a brand new fiberglass pool at the beginning of the summer and I didn't have any problems for the first 3 months. My water chemistry were good and everything was balance (I check the chemistry every week). I have a salt chlorinator and I maintain everything in the good parameter.
After 3 months, I realized that my pool walls and steps were yellowing a little bit. So I waited and the end of the summer (right now), to making a AA treatment for removing the stains (that's what my fiberglass company told me to do). I was pretty sure the stains come from my backyards construction (installing concrete paver around the pool etc...). By the way, I have a pool defender inline anode wiring to a pole in the ground so it helps to prevent positive ions in the pool.
Before I used the AA treatment (citric acid), I was making sure that my water chemistry was good for making the treatment and here's the parameter:
Alkalinity: 80 ppm
Hardness calcium: 200 ppm
pH: 7.2
Chlorine: 0 ppm
Phosphate: 0 ppm
Iron: 0.0 ppm
Cooper: 0.0 ppm
So, I start my AA treatment in the pool and I was making sure that my pump was still running 24/24 for this process. A day later, the stains disaspear and the pool was really clear so, after that I brush the walls and clean the pool. After that, I put a Metal control to the pool for making sure that my metallic particles will be in suspension and my sand filter will take the majority of the metal particles.
I waited 1 week before adding chlorine with my salt generator and the day after I did that, my pool turned yellow/green. And I didn't make any shock chlorine, I just started my salt generator at the minimum and my pH level were at 6.3.
After that, I saw that the stains have reappered at the same spot and were yellow. So I realized that I don't have removed entirely the metals in the pool and that reaction was probably cause by oxidation (if i'm not wrong because i'm not an expert).
So, i bring a sample to my pool store to check if I have metal particles in the pool and surprisingly, there's none and the agent of the pool store told me it's probably algea that have growth but i doubt it because i did this AA treatment at this time of the year because I'm from Canada, and right know the pool temperature is approximatively 62. And the pool turned yellow/green pretty clear right after I start my salt chlorinator and the day later I was at 0.7 ppm chlorine.
Now, I wanted to get rid of the yellow/green water from my pool (see photo from attach files) and i tried the cuLator metal eliminator in my pump strainer and I put polyfill fiber in my skimmer. And, the same day i gradually rebalanced my pH, alkanity and chlorine really slowly. The day after that, the pool was really better and my Culator pouch was brown color and my polyfill too so I presumed that I have iron right?
So I write this message, to have some help in the future of what I did wrong or what should I do to remove the stains if it's really iron. Because I supposed it's this, but I'm not an expert and by the way, I didn't fill the pool with a well, the water came from a municipality water.
Thank you in advance!
Alkalinity: 80 ppm
pH: 7.2
Chlorine: 0 ppm
Phosphate: 0 ppm
Iron: 0.0 ppm
Cooper: 0.0 ppm
