I have both Taylor K-1001 and K-2006 so I tested pH and FC for the same pool water using two different kits. The pH readings were close but the FC differed by 1ppm. Using R-0001/R-0002 with color matching, I get FC = 2.0ppm, while using R-0870/R-0871, I get 3.0ppm (0.2 x 15). Does this mean the R-0001/R-0002 method always "underestimate" FC or it is just simply less accurate (as +/- 1ppm)?
K-1001 was from the previous home owner. All reagents will expire at the end of this year.
