I was thinking about what would be the fastest way to heat my pool with my gas heater. Should I heat up the spa first since it heats so quickly by re-circulating/heating the warm water and then once it's up to 100 degrees adjust the valves to normal so that it overflows into my pool? Or should I just keep the valves normal, where water is taken from the pool and returned to both spa and pool? Just a thought.
Thank You!
Thank You!
