Howdy! We had our in-ground pool built a year ago and have had zero problems with it since startup. Until early this month...the lower (low pressure) bulkhead fitting on our Triton II TR-100 filter developed a small crack that leaked under higher pressure from the pump. Slowing down the pump stopped the leak, but air would suck in and bubble out the return jets. Builder replaced it under warranty, but commented that ours was the third or fourth one they've seen happen in the area. All on filters that had been installed last year. Same lower bulkhead, same Pentair Triton II TR-100, same crack in the same place on the fitting...
So is this a thing elsewhere in the US?
