Do you have another one? You need a gasket.
Aside from that, Other than you probably noticing where it fell for as long you have that liner it shouldn’t be a problem.
I have plenty, the issue is that it's so tight I can't get the liner out of the track to fit another. Can I put the gasket between the plate and the liner on the outside?
Sometimes there will be a cork one if you buy a new return fitting - it goes behind the liner (between the liner & the wall), the rubber one goes on top (between liner & fitting plate)
