I finished installing the my Aquacal Tropicool. It’s downstream right after my pentair gas heater. I want to tie it into the Easytouch panel.
I have read and watched online what I have been able to find and the wiring between the chiller and the easytouch makes sense - wire B port on chiller to RS485/COM port on easytouch and add solar sensor.
Once I wire everything up, I need to enable “heat pump” via the easytouch menu.
The question I have - will the Easytouch regulate the temperature once I enable the chiller/heat pump? Example - If I turn on the pentair heater, will easytouch disengage the chiller?
Everything I’ve read / watched discusses a heat pump with cooling/heating ability and thus when enabling the heat pump in easytouch you enable it for heating and cooling. Since my heat pump is a chiller only, I assume I only set easytouch to enable chilling.
Thanks- this forum has been excellent thus far in working on pool things!
