TX Splash - that's pretty in line with what I was thinking. Use the test that is more appropriate for the need.
Dave - The range is what I was alluding to, where most of the time you're testing to simply make sure your experience matches reality. So I typically test in the evenings as the sun goes down, and I expect to be near the bottom but still within the optimal range. Usually I am, but occasionally I've found I'm lower than expected. I hadn't considered the color blindness aspect though, that does make perfect sense.
Don - If you want hyper accurate numbers for every test, that's up to you and nobody is trying to take away your cookies. But will it really matter in the goal of keeping our pools clean? I'm all about the increased accuracy in the cases where it truly matters, but for daily "rationality confirmation" I'm thinking it isn't necessary. Even in your alternate test examples, ranges still apply. When my blood pressure is checked, the doctor doesn't care if the accuracy of the sphygmomanometer is within 0.01mm/Hg or even 1mm/Hg. Most of the time if they're using a cuff and a stethoscope, they're aren't waiting for each heartbeat before dropping the pressure in the cuff - so they're introducing a very large margin of error there as well. They just want to make sure I'm close to my typical healthy range.
