dots in bottom of pool?
Nov 11, 2012
24
Illinois
Hello! So i noticed i have a few tiny brown/black dots on the bottom of my pool? They almost look like little rust stains? They don't brush off, i tried picking at it with my toe, couldn't feel anything and nothing came off. Is it algae? Water has remained clear, bbb method has been working great so far. Pictures attached, thanks!
Before we immediately jump to the conclusion that this is black algae,
:testresults:
Also, what type of surface does your pool have (e.g., plaster, fiberglass, vinyl)? Sometimes it is hard to tell from the pic.
The fact that the water is clear is a good sign. Another possibility (a long-shot but I will put it on the table)...Did you recently get the pool refinished or recently move into that house and just now notice these spots? When I first moved into our current house (knowing nothing about pools at the time) I hired a pool tech to give me a "pool school" of sorts in showing me how to operate the equipment. When we got to the spa, we noticed similar spots. Pool tech first thought it was black algae. Turned out to be anti-slip particles about the size of the granules on an asphalt roof shingle.
Let's post the test results and go from there.
Thanks for the reply!
The pool has a vinyl liner. We moved into this house about a year ago, and this is the first full pool season for us, and the first time we have noticed these spots. They are only in 1 small area of the pool...
I may be very likely imagining this, but I think the spots have changed since I first noticed them. There may be a good chance I am imagining that, but I thought I would still mention it. :-D
Current test results are below, thanks!
FC 8.5
CC .5
pH 7.7
TA 110
CH 190
CYA 60
Your test results look good. Just keep an eye on the CC. At 0.5 ppm you are just below the threshold of needing to SLAM. You can also try an Overnight FC Loss Test. That test may provide more insight as well. If you lose more than 1 ppm of FC on the Overnight FC Loss Test, please post that fact.
One other quick test you can perform to see if the stains might be metal-based is to try rubbing a vitamin C tablet on a couple of the stains for about a minute or so. If the stain lifts, then it is a metal stain. If that's the case, please post your findings.
In the meantime, I would continue keeping FC in the range of 8-10 ppm which is at the high end of the recommended range for your pool's CYA (see Chlorine CYA Chart), and brush the spots with a nylon or similar soft-bristle brush (no stainless steel on your vinyl liner) at least once a day. See if the spots diminish or go away after a week or so.
If you can't scrape anything off, it's not black algae...though the shape of the spots certainly resembles it. If you put on some goggles and dive down there, black algae will look like little fuzzy slimy bumps, and will easily scrape off on your fingernail.
Update!
So I finally got some goggles and took a dive down there... it is not algae.
It looks like little brown rust spots. I can pick at them with my fingernail and get a little smear, but not much comes off. So what is causing these rust stains? What's the best way to get rid of them? Vitamin C tablet?
Reactions: Amyb9111
chiefwej said:
If its an inground pool, has anyone fertilized grass near the pool?
It's an above ground pool, with no fertilizer on grass near it.
I can only think of 2 ways metal could've gotten in there...
Either fertilizer or something blew into it from the fields near my house.
Or, it is in the water I put in. I haul water from a nearby town, not sure if that could have metal or not...
Would it hurt anything if I leave the spots alone? I can try to rub vit C tabs on them, but there are a good number of little spots. I read about the ascorbic acid treatment, maybe I could do that in a month, when it gets cold and I'm about to close anyway. Any other options?
Thanks!
