Dolphin Triton PS pool cleaner not moving?
Oct 19, 2016
41
Huntsville, AL
Purchased this cleaner in May of 2019. I've kept it maintained, basket and filters clean, etc... Never ran it dry.
Today I attempted to turn it on, and nothing. The power supply is on, but the cleaner doesn't do anything at all. Any suggestions as to what to check first?
Hey NLambert!
We're very sorry to hear of the issue you have encountered with your Dolphin robot.
First of all, we can suggest you try the following troubleshooting steps:
Caution - Make sure the power supply unit is unplugged from the outlet. 
1. Turn the robot upside-down. 
2. Try to rotate the brushes and tracks both ways, you should feel little resistance. 
3. If you hear any noise ('clicking noise') or feel more than a little resistance, this indicates that probably something is stuck in the tracks or brushes.  
4. You can try to reach in and release the object stuck in the system. 
Caution - Do not use an Automated drill.  
We recommend looking at the PowerStream system as well to make sure nothing is blocking it. This is the plastic cover above the impeller and the grilles on the sides of the robot. 
Also, please check if the servo cover is well seated in its place, via this video: https://youtu.be/Wqxpt0bg5AY
If you notice debris trapped in the impeller, open the impeller, remove the debris, and reassemble it. (Use a Phillips screwdriver). If the debris is not reachable, follow the steps in the attached video:
Additionally, you're more than welcome to reach out to us via a private message so that we could look into this and provide further assistance.
Hey NLambert!
Hi, I'm also having the same issue.
Power supply on, robot runs for 10-20 seconds, stops.
Nothing blocking impeller.
Is there a reset button on the robot?
