- Oct 31, 2021
- 34
- Plaster
- Jandy Aquapure 1400
I have a S300i about 2.5 years old. It started to have the following issue recently.
When starting a new cleaning cycle, it moves back and forth, then the impeller will start pushing water but only for about 15 seconds. The robot would keep moving for about 5 minutes with impeller not rotating, then it stops completely, and the button on the power supply turns red.
I have read a lot of post and YouTube video. First, I switched to another Power Supply which is known to work, the cleaner still behaves the same. Then I opened the motor assembly and there was no water invasion. I disassembled the impeller motor and found a lot of carbon dust due to the worn of the motor brush. The brush is pretty much worn out, so I replaced the carbon brush of the motor. However, after putting back everything, the robot still behave the same.
How to troubleshoot next? What could be the component could cause this issue?
Any suggestion is appreciated.
