I have a dolphin active 30i. It was given to us. Drive motor was seized and impeller motor made a grinding. Replaced both with parts from a pool supply place. When powered on, no self test. All lights up fine on power supply. Light on front of the unit also lights up. Syncs with blue tooth ect but dead in terms of response. Nothing happens…crickets! App just gives a message that something went wrong. No kidding
Found a few informative videos on troubleshooting the power supply, however, they are for older models with 2 pins. Mine has 3. Likely not that hard but I find it a little confusing when you measure the dc voltage because one is 22+, another is 6.8 …do I add them. If someone could please offer advice as to how to properly connect the leads from my circuit test multimeter, it would be much appreciated.
