I am looking to reduce the electrical consumption of my above ground pool. It is 18ft round, 7700 gals, 40 sq ft DE filter. Electrical supply is 115v only. Currently I have a 1HP 115v Hayward Powerflo Matrix, rated at 12 amps and pulls about that, plus or minus a few amps depending on the load. I have added rooftop solar this year but still feel like it's oversized for my needs. Previously I reduced consumption by only having the pump come on for 3 hours total per day, but with the solar system I will now want to run continuously 10am-4pm.
I would like to stick with a horizontal discharge above ground pump rather than custom plumb an in ground pump. VS above ground pumps barely exist, Hayward has one they don't sell, and Doheny's has one they don't ship to California. I think two speed pumps are out of the question for me now with the solar system, I doubt the .15-.25 HP low speed on any of them will be adequate.
That brings me to this pump, a rebranded Harris single speed above ground pump. I previously was only considering name brands but this appears to be a special product, I believe it is cap-start, cap-run, and that cap-run will be particularly beneficial to me for efficiency. I know the powerflo matrix are completely non cap, and I'm not sure about the optiflo but it doesn't have a cap hump so I'm pretty sure it's at least not cap-run.
What I'm confused about is the small difference in amperage ratings:
3/4HP - 5.3 Amps
www.doheny.com
1HP - 5.6 Amps
www.doheny.com
Considering 1HP to be overpowered I still think 3/4HP is the safe choice, and that the amperage difference will be greater in reality than their ratings. But I'm still curious to know if anyone has an idea what gives here, or a recommendation to go with the 1HP in this case.
(For the eagle eyed, yes those pumps are only available in vertical discharge and Doheny's says they "shouldn't" be purchased for conversion to horizontal, but I'm betting it's possible even if it voids the warranty)
3/4HP - 5.3 Amps
Doheny's Energy Efficient Above Ground Pool Pump, 3/4 HP - Doheny's Pool Supplies Fast
Are you looking for Doheny's Energy Efficient Above Ground Pool Pump, 3/4 HP? Doheny's has this item in stock now. Click to see our low price.
1HP - 5.6 Amps
Doheny's Energy Efficient Above Ground Pool Pump, 1 HP - Doheny's Pool Supplies Fast
Are you looking for Doheny's Energy Efficient Above Ground Pool Pump, 1 HP? Doheny's has this item in stock now. Click to see our low price.
