Hello, I just read an article about pool testing results and things that can compromise different tests. One of the subjects was when testing TA, the TA test in the Taylor test kits can give you a false high TA level if you have any cya in your water. They say to compensate for this high reading you should deduct 1/3 of your cya level from your TA test reading to get the correct reading. Can someone please let me know if this is the case?
