Do I need to seal my hot tub tile grout.
tribly
0
Jul 31, 2014
19
Portland, OR
Finally got around to tiling my in-ground hot tub I built a few years ago. The tile is in and grouted. Normally with a tile project I'd seal the grout afterwards, but I've been reading around online a bit and it seems many people say you don't need to seal grout in a pool (it's not part of the waterproofing and not likely to get stained).
Just wanted to ask specifically if you think I should be sealing the grout it or if it's just a waste of time.
Tiles are 1" x 1" porcelain. Grout is Custom Building Products Prism Grout if that matters.
Some links I found on the topic:
https://www.troublefreepool.com/threads/85754-DO-YOU-NEED-TO-SEAL-THE-WATERLINE-TILE-AND-GROUT-fng-pool-build-in-AZ
http://www.johnbridge.com/vbulletin/archive/index.php/t-31837.html
Also, a photo just for fun:
I sealed our waterline tile on our fiberglass pool. Primarily to reduce calcium from plating out on it. Have to say it did not do a great job of that.
Looks great!
Take care.
