This was our old setup. Gravity made self priming easy. The lake flooded and covered the two pumps for about 3 weeks. It will probably happen again, so we moved the electrical box, pump, and filter up above on the deck. The concrete wall on the left shows the 1 1/2" pipes coming out. This is below the bottom side of the pool. We had 1 return with a pool cleaner and pump that we did not replace. So now we have 3 returns instead of 2. We have a main drain and only one skimmer.
With this setup, we never had air bubbles in the pump or coming out of the returns.
Now we have lots of bubbles and it takes a while to prime the pump. Anytime the pump is off, the water seems to go back into the pool. The strainer basket never gets full of water when we put the hose in it. Water goes back into the pool. By the time we get the pump lid back on the basket is empty again.
The plumbers added 2" pipes to the original 1 1/2" pipes, then ran the pipe up about 7 ft, then over about 15 ft, then up another 1-2 ft to the deck above. Gravity is working against us now. In the last picture you can see the new location of the filter in the top left corner.
It won't let me post another picture. Will try later.
So....is there anything we need to have installed? We don't have an air release valve since we didn't need one with the gravity setup. Do we need one now?
