- May 2, 2017
- 104
- Plaster
- Hayward Aqua Rite (T-9)
I have a pretty basic pool pad setup. Built Right Heat pump, Pentair VS Superflo, Aquarite SWCG, Pentair Intellibrite light. I only have a single valve that allows me to control suction between skimmer and main drain.
I would like to be able to do the following....
1. Turn Heat Pump on and Off - even better if can set temp
2. Set pump speed - I believe mine can only cycle through the 3 different presets which I would be fine with
3. Lights - On/Off/Change color
4. SWCG - I don't know what's possible with mine. Being able to turn it on and off isn't much value, but if I can set output and be alerted when not generating because of some type fault, that would be great
5. Monitor Water Temp
6. Monitor and Control from Android phone
7. (This one is just a nice to have by-product, not a deal killer if better to keep seperate) I have some home automation now. Currently I have a lot of Kasa Light Switches/Dimmers, Ring Alarm and Cameras, Logitech Harmony Hub, Ecobee thermostat, etc. It's mostly controlled by voice via Google Home's or by Android phone using Google Home app. However, because each manufacturer of devices has limitations on what it works with and what functions are available, I have automation logic spread out between Alexa app (integrates with Ring and can controls lights based of detected motion, times of day, etc), IFTTT, and at least one or two other I am not thinking of. Would be great if I could centralize all of that in a local system.
I did some reading on the forum, so I have a general idea of what I am getting in to. I do development in C# and lots of SQL work professionally, so comfortable with coding and working with custom solutions. I have built computers, wired and plumbed my existing equipment....so thinking shouldn't be to difficult for me to accomplish what I want.
My main questions for the group....
1. What hardware should I be looking at considering the equipment I currently have? I don't have a set budget, but would like to keep it reasonable. I prefer to buy stuff that will be the least finnicky and most reliable.
2. Will it be possible to do what I want from my list above? Not sure if it's worth the effort just to be able to turn stuff on and off without being able to make adjustments to heat, pump speed, etc.
Thank you as always, this place is a wealth of information.
