Hello all,
So as I'm sure everyone knows, COVID did two things to the pool situation:
1) Limited accessibility to public pools
2) Eliminated the availability of moderately priced Above Ground Pools
So I had a concept for building my own steel wall AGP and I wanted to ask if this was feasible.
I'd like to use pieces of corrugated steel roofing (e.g. Classic Rib Steel Roof Panel in Charcoal at Home Depot) , bolted together to make a round pool.
These come in 3 ft sections that are meant to overlap at the seam. You can get them prepainted in a few different colors. I would cut these to my desired pool height, bolt them together, and bolt some aftermarket beaded liner receivers along the rim.
I would think the cost of panels are reasonable and as long as I paint/seal any cuts or holes in the roofing and use galvanized fasteners, I shouldn't have too much rust problems.
The corrugated nature of the panels should give it rigidity to support the vinyl liner walls, yet allow flexibility in the other direction in order to form a ring.
Is this something that seems viable?
Would I need some kind of uprights along the perimeter of the pool wall?
Is there some kind of engineering principle here I'm not considering?
