Can someone check my math? I have a 5900 gallon above-ground pool. If I use Dichlor, each 10oz puck will raise my FC by 7 ppm and my CYA by 5 ppm. So, over the course of a month, consuming 3 ppm FC daily, let's say I use 13 pucks. That will give me 91 ppm of chlorine and will raise my CYA by 65 ppm. Since I started at 50 ppm CYA, I'll need to drain & refill at least half of the pool water to get the CYA back to 50-60 ppm CYA. That's at least 3000 gallons of water. Based on recent water bills, at $28 per thousand gallons (includes sewer and taxes), that comes to $84 per month, not including the price of the pucks. Last time I bought a 25-lb bucket of Dichlor it was $100 (price has gone WAY up since then), that's 25 cents/oz, so 13 10oz pucks would be $32.50? Total monthly cost is $84 + 32.50 = $116.50 per month?
If I use liquid bleach, I can get a gallon of 10% chlorine at the local Walmart for about $6. Each gallon of bleach will raise my pool 17 ppm FC, so I'd end up using 5.35 gallons of 10% bleach to get the same 91 ppm of chlorine, at a total cost of $32. Unless something happens, likely the CYA will stay at 50 ppm, so no need for further chemicals.
If my math is right, I'm saving $84.50 a month MINIMUM by using a Stenner vs buying Dichlor and dealing with massive water changes. Or is there another way people deal with the CYA buildup? I see a *lot* of pools with Dichlor feeders.
TIA
-Mark
TIA
-Mark
