Hi there... I'm new to the forums and hoping to find some advice/answers regarding a dedicated tablet for a control to Hayward OmniLogic. I just put in a new pool and had an OmniLogic system installed for automation. I've been able to spend some time with the system I'm learning about some of the limitations. I have an android tablet mounted on the wall just inside the back door and had hoped I could load the OmniLogic App and leave it loaded at all times for a "build your own controller". After loading the app (and contacting Hayward support) I learned the app does not support landscape view (horrible UI design). I then switched to the web interface via Chrome and oddly enough landscape view is supported however the website times out after so many minutes of inactivity and I'm required to logon again. Not an ideal solution either.
Has anyone else attempted to create dedicated controllers using Android or Apple tablets? If so any best practices or things you found out that worked well?
Thanks!
Thanks!
