Deck Replacement
watsonk
1
Cincinnati
The decking can be demoed and replaced, but I would suggest:
-Leave the pool full of water during the work, to keep the walls from collapsing into the pool
-Do the demo work by hand, not with a skidsteer or excavator. The walls are tied into the deck by rebar that runs up the back of the walls and is then tied to the rebar in the deck.
-Put the plumbing under pressure before the demo work starts, and until the deck is fully poured.
-The right contractor can remove those white coping strips and pour the new deck with a cantilever form.
-The rebar coming up from the back of the walls MUST be retained and tied back into the new deck. It is the only thing keeping the top of the walls from
It looks like the tile is set in a track, should be straightforward to remove it and reset some new tile.
The rust looks to be from a seam in the panels. Depending on how far you want to go with this thing, you could have the paint blasted off (I would use hydroblasting or some alternative to sand blasting to minimize mess and likelihood of making holes in the walls). After that, the walls should probably be primed with some kind of rust inhibiting primer, then repainted and the seams re-caulked.
The floor can probably be prepped and replastered - nothing special needed.
On the deck, I have also seen people use L-shaped renovation pavers to cover up the deck and the white strip. Might be worth looking into.
MAPR-Austin; Thank you for sharing your expertise here!. My in-laws just got a quote from a landscape design co to tear up and re-pour the deck around their inground liner pool. My gut told me that perhaps the deck is somehow tied into the pool walls. The quote includes a lengthy paragraph absolving them of responsibility to any damage to the pool, etc. Separately, this (Spartan) pool has an old aluminum coping that has corner pieces out of place. Do you know how it likely attaches to the wall? Are they possibly integral to the liner track, or can it be taken off and replaced with new metal, or poured coping (as with the Stegmeier forms)?
I'd have to see pictures (especially on the aluminum pieces question), and I must offer a disclaimer that I have limited knowledge of liner pools...
But yes, in every one that I have come across the pool walls are tied into the pool deck. Most often with rebar that is integral to the pool walls, and then bends over at a 90 degree angle to tie into the rebar in the deck.
If you can post a couple pictures of the aluminum trim I may be able to give you some advice.
Reactions: kimkats
